Network DVD players - what are the options / worth it?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Luc, Jun 30, 2005.
  1. Luc
    Luc
    Aug 7, 2000
    420
    Having just sold my H/K DVD25 (thanks common!), I'm looking to upgrade, probably to a Momitsu v880N, but having been told about the build quality issues, I'm starting to re-think it (I'm a quality whore). This is to be connected to a Panny 5 series via component.
    Are there any current (ie, players that are available NOW) network players (hard drive not essential) which offer the following;
    - DivX/Xvid/WMV9 playback
    - PAL/NTSC prog scan via component
    - HDMI (not essential)
    - Decent build quality (remote is unimportant, i've got a Pronto)
    Or, are network players still in their infancy? Are the benefits of not having to burn everything to CD/DVD outweighed by their lack of maturity? Would a decent quality standard DVD player that handles DivX/Xvid be a better option?
    I'm not looking for a PVR, the ability to stream internet radio, or any other superfluious gubbins, and HTPC is a little out of my budget (If I were going that route, I'd go MacMini), so let's not go down that route just yet.
    Any opinions / thoughts?
  2. Luc
    Luc
    Aug 7, 2000
    420
    Anyone heard anything about the 'QUARTEK WHD500-V9 WiFi DVD/DivX player' ? Pixmania have it listed for the beginning of July, and it looks like exactly what I want, but it seems like only the europeans have heard of it.
  3. JimmytheSaint
    JimmytheSaint
    Mar 21, 2003
    1,793
    London
    +100
    The V880N has no build quality issues! The older model V880 had some issues, but I've heard or seen NO quality issues with the DX or N series.
  4. nealgs
    nealgs
    have not seen any build quality issues with our V880N at all, it's a very neat and tidy unit, an heavier than our ancient Pioneer 525 player by quite a margin yet is only half the height.
    Only problem i've had/got with the V880N is the inability to play R1 Extreme Edition of Blade Trinity (some people would think this a good thing :devil: ) but i've copied the Film & DTS audio track to my media server upstairs and streamed it over the network (need a 100mb switch as 10mb hub was getting swamped at times)
    Excellent quality (other than network speed causing collisions) so managed to watch it :)
    Picture quality is excellent at 1024x768 dot by dot mode via DVI to our 433MXE plasma :thumbsup:
    It doesn't play WMV9 files though IIRC, but maybe possible with firmware update??? if ever done
    Gary
  5. Luc
    Luc
    Aug 7, 2000
    420
    OK, so it looks like a toss up between the Momitsu v880n and the QUARTEK WHD500-V9 (when it's released next week - if it is) - the only questions I have when upgrading is "will it be better than what I've just got rid of?". Nealgs - what were you coming from before? Can anyone say how the Momitsu component output compares to my previous H/K dvd25? And has anyone ordered direct from Momitsu.nl before? Ta.
  6. nealgs
    nealgs
    previously had a Pioneer 525 as mentioned (circa 6-7yrs old) gr8 player, but was having problems playing some of the newer DVD releases etc due to what appeared to be it struggling with hi bit-rate content.
    So was looking for something else but not to expensive, originally had the Philips 963sa and Momitsu V880(N) and the Samsungs on my short list.
    Went for the V880N as a forum member had one for sale that was only a month or so old, bought directly from momitsu.nl it was to (he had no problems with the purchase IIRC)
    Image is much, much better than the 525, and i've also briefly tried the 963sa that Play had on for sale. V880N was miles better pq wise in my opinion, especially with the 720p upscaling it can do over component and DVI.
    regards
    Gary
  7. Luc
    Luc
    Aug 7, 2000
    420
    OK, got hold of a Momitsu v880n yesterday, and inital impressions are good - the network playback is great, picture is good over component, but, (and it's one of those buts that might force a return) the disc access is incredibly noisy. Is/was anyone else's drive noisy to the point of distraction? My HK/dvd25 could just about be heard when changing layer, but the momitsu has a constant whine to it - I can imagine it being very annoying in low level scenes. Does it settle down, or am I destined to house it under a duvet?
  8. nealgs
    nealgs
    not noticed any noise issue with ours. Our 525 was very noisy, but the v880N is nigh on silent and doesn't distract from picture. If anything the blue network activity light causes more distractions due to it being so bright :)
    Gary
  9. JimmytheSaint
    JimmytheSaint
    Mar 21, 2003
    1,793
    London
    +100
    No issue with noise with mine either. I suggest you get a replacement.
  10. Luc
    Luc
    Aug 7, 2000
    420
    Tell me about it - it's like some kind of beacon for aliens. I'm going to watch The Incredibles tonight, and if it doesn't settle down (might have been the one and only disc that's been in it that was noisy), I'll mail Jan-Hein (top bloke) and see about a replacement. Shipping back to NL might be pricy though...
  11. Luc
    Luc
    Aug 7, 2000
    420
    Having sat through a whole film with it, it's one of those annoying sounds that when you hear it, it's all you can hear, but it dissapears into the background sometimes. It's a high pitched whine, like crickets on speed - it might be a subjective thing, and I don't want to kick up a fuss over nothing, but it's about 3x louder than my PS2. Does this sound more like anyone else's, or is it definately dodgy?
  12. seanm
    seanm
    Mar 1, 2002
    1,279
    48
    +44
    mine too is quite noisey, espeically upon first loading.
    Have not contacted momitsu, as I can just about live with it.
    Great PQ and hesitant about losing it for a couple of weeks.
    Let me know how you get on.
    Sean
  13. Luc
    Luc
    Aug 7, 2000
    420
    Momitsu support are all on holiday for a couple of weeks apparently, so Maarten Streppel has promised me an answer when they get back. I'll update when they do so. Watching Xmen2 last night, it wasn't as noticable, so maybe it's calming down, but I think it's just because I had it turned up to deafening levels.
  14. Luc
    Luc
    Aug 7, 2000
    420
    Does that make sense to anyone? Can't think why my H/K dvd25 outputting at 480p would need less data than the v880n at 480p...
    Another problem I found is that on a layer change, it will pause for 5 seconds, stutter, then pick up the picture again - takes about 10 seconds overall. Might just be with R1 discs i think - anyone else had similar problems?
  15. ErikX
    ErikX
    Sep 14, 2004
    84
    The QUARTEK WHD500-V9 now seem to be in stock at several European webshops.
  16. Luc
    Luc
    Aug 7, 2000
    420
    Anyone? Or should I kick my toys out of the pram, get a refund, and try the Quartek?
  17. seanm
    seanm
    Mar 1, 2002
    1,279
    48
    +44
    Does the Quartek upscale standard DVD disks?
  18. Drew2
    Drew2
    Jan 12, 2005
    699
    Tsukuba, Japan
    +32
    Does anyone know if a universal remote can be used to control the Momitsu?
    Haven't got the original to re-program another unit.
  19. seanm
    seanm
    Mar 1, 2002
    1,279
    48
    +44
    Yes it can.
    I used the original remote to program my Yamaha 757 Universal Remote.
    (the momitsu remote is dreadful)
    Try www.remotecentral.com
    Any updates on the noisey drive? mine is now really frustrating me. emailed Momitsu.nl support a week ago and not had a reply.
  20. seanm
    seanm
    Mar 1, 2002
    1,279
    48
    +44
    Also been looking at the Quartek. Cant see anything about upscaling DVD through DVI like the Momitsu does very well.
  21. Luc
    Luc
    Aug 7, 2000
    420
    I've lived with it for a week and tried to put up with it, but I don't thikn I can anymore. I've mailed support to try and get some answers, so I'll let you know what they come back with.
  22. Drew2
    Drew2
    Jan 12, 2005
    699
    Tsukuba, Japan
    +32
    Try contacting Momitsu at:
    support@momitsu.com
    I got a reply within a day - which impressed me! :smashin:
    Havent noticed any noise from drive,just shocked about the noise it makes when it opens/closes :eek:
  23. Drew2
    Drew2
    Jan 12, 2005
    699
    Tsukuba, Japan
    +32
    Update with my contact with Momitsu.
    My new remote arrived this morning, exactly one week after mailing them! hows that for dynamite service :thumbsup:
    Have now had opportunity of playing DVDs and Cds and can report that the drive makes very little noise.Need to have my ear about 75mm away from casing to start hearing it. :)
    completely satisfied with player - outstanding product :cool:
  24. Luc
    Luc
    Aug 7, 2000
    420
    The noise/layer change issues I had turned out to be a faulty drive - Martijn @ Momitsu shipped me a new one for me to install (save shipping the entire unit back to NL), and a quick 10 minute install later, it's much better. Almost silent now, and much more responsive layer change. Well done Momitsu for sorting me out.
  25. Drew2
    Drew2
    Jan 12, 2005
    699
    Tsukuba, Japan
    +32
    Good to hear you got your problem sorted.
    With such a new company in it's "infancy", they're bound to have "teething" problems - but good that they're quick to hand with the "pacifier"
    Have now watched all LOTR dvd's and they look totally amazing - I can feel the textures and the scenery just goes on & on. ;)
  26. seanm
    seanm
    Mar 1, 2002
    1,279
    48
    +44
    Hi Luc,
    I had the same problem with the noisey drive.
    They too sent me a new loader rather than sending the whole unit back.
    Piece of cake to change, and now its alot quieter. Praise to Momitsu.
    They were advertising that the V880N was going to have a Video Input Module available.
    Which would upscale an input source, they have now removed any reference to this from their website.
    But it would be nice to see!
  27. nealgs
    nealgs
    unfortunately there isn't anywere on the V880N unit to actually plug this device in without taking a hacksaw to the case, but as you say, it would be nice to have something like that.
    Gary
  28. Drew2
    Drew2
    Jan 12, 2005
    699
    Tsukuba, Japan
    +32
    If your machine has a scart socket it could be possible, It's an in/out port!
    Would prefer they 'binned' the Video & L,R jacks and made them composite in..
    Now that would be good - upscale my PS2,lovely! :)
