Network Drive Letter updates - Help please
Discussion in 'Desktop & Laptop Computers Forum' started by Messiah, Oct 17, 2004.
  1. Messiah
    Messiah
    Apr 22, 2002
    7,624
    +338
    I have just added some new HDDs to my server and made some changes to the drive letters. Unfortunately, when I now bros=wse the Fileserver from another PC on the network it is not showing the revised drive letters. Even if I do a refresh it will not update the drive letters. If I browse a drive that is showing with the old drive letter it does actually show the contents of the new drive that actually belongs to that drive letter.
    This is very annoying. Anyone knoe=w how I can foce My Network Places to show the updated drive letters?
    Thanks.
    Yours
    Frustrated :confused:
  2. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,149
    41
    NW London
    +18
    try deleting the auto added network shares on the remote computer. Sometimes the refreshing doesnt work for some reason because although the physical disk has changed - the drive letter is still there so windows may not update the name.
  3. Messiah
    Messiah
    Apr 22, 2002
    7,624
    +338
    Thanks. Done that. But no difference. I've even switched both the fileserver and the network PCs off to try to get themn to rescan the network but no luck.
    Also, despite setting sharing on the new drives it won't display those letters for the newly added drives.
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    This is typical of the rubbish that is M$ networking .. while I'm no expert it's clearly a problem with network browsing and the action of the Browse Master, that fact you can see the drives when you know they're there indicates this.
    I must say I've not come across a case where the drives refuse to show up for a long time, however you may want to try manually mapping them:
    1) open a command prompt
    2) on a client machine, decide on a drive letter you want to use and the name of the shared drive you want to map it to, then enter this command
    net use driveletter: \\servername\sharename
    for example:
    net use r: \\myserver\f
    to map R: to drive F on the server. If all goes well you'll now be able to see R: in My Computer and Network Neighbourhood hopefully.
    By default this mapping would also be permanent, it may just prod the browse master into action. It's possible to fiddle with the Browser service (nothing whatsoever to do with Internet Explorer BTW!) if this doesm't work.
