Netgem's USB connection
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Clint C, Apr 14, 2004.
  1. Clint C
    Clint C
    Dec 10, 2002
    425
    Wiltshire UK
    +4
    Hi there
    Can anyone tell me the fastest USB Ethernet adapter that's available for the Netgem i-Player? I want to maintain the 100Mbps connection I currently have on my network. The Dlink Dub-E100 looks like a good one to get and I believe it's one of the Netgem recommendations but is it as good as it sounds? Has anyone had any problems with this one? Is there a better one out there?
    Thanks in advance
    Clint.
  2. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    I tried the E100, but it didn't work at the time. I swapped it for the 10Mbps version and that worked fine. That was ages ago though - there's been software updates since then.
    This thread shows someone has used the E100 with some success.
    Cheers, Carl.
  3. Clint C
    Clint C
    Dec 10, 2002
    425
    Wiltshire UK
    +4
    Thanks for that Carl but does anyone know of a reliable 100Mbps connection possibility?
    Clint.
  4. Tee Tee
    Tee Tee
    Apr 3, 2002
    125
    Shropshire
    +3
    I think the limiting factor here is the USB 1 interface on the Netgem. The fastest throughput would be about 12Mbs IIRC.
  5. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    Agree with Tee Tee - I don't think the USB will handle full 100Mbps. Besides, I can't see that it needs it. About the most demanding thing it can do over it's net connection is stream music, and you don't need much bandwidth for that.
  6. AOD
    AOD
    Feb 7, 2001
    714
    London
    +5
    I'm using a Belkin USB adaptor with my Netgem which handles supposedly 10 & 100, although as already stated, the limiting factor here will be the USB connection on the Netgem.
    The adaptor is here
    I also tried it with my laptop and it worked out of the box (as you would expect). My laptop's NIC doesn't seem to pick up IP addresses via DHCP (when upgrading the router firmware you have to use a cable, not wireless) so this is ideal for this as well.
  7. andy572
    andy572
    Dec 4, 2002
    362
    Oop North
    Unfortunately, both guys are right, clintc.
    Soon after buying my Netgem last year, I noticed the fact that everything had to squeeeeeeze into that little USB port passed most Netgem Forum members by.
    The majority wanted to use the box as a 'media centre', chucking everything they could through the theoretical 12Mbps 'pipe'.
    As it happens, my adapter should arrive tomorrow. Obviously, I can't recommend it yet; but it's the Belkin F5D5050. It's an adapter that was on Netgem's compatibility list when I started looking into the box, last year - and one that seemed 'reliable', in terms of setting-up. Having said that, I shouldn't think there's much between brands.
    If it is of interest, unlike last year, I've only found the Belkin here, here and here - though I'm not familiar with the latter two on-line stores and the second of the three places was approximately 50% more expensive than the first one!
    Of course, there may be other places - but I gave up clickin'! :clap:
  8. Clint C
    Clint C
    Dec 10, 2002
    425
    Wiltshire UK
    +4
    Cheers for the info guys... :smashin:
    Clint.
  9. Clint C
    Clint C
    Dec 10, 2002
    425
    Wiltshire UK
    +4
    I've ordered the Belkin from Ebuyer :smashin:
    Clint.
