Netgem iPlayer now has component output!
Discussion in 'Plasma TVs Forum' started by Rob100, May 25, 2003.
  1. Rob100
    Rob100
    Nov 3, 2002
    3,482
    +227
    I know this belongs elsewhere, but this info could be of most interest to Plasma owners.
    The latest software 4.2.2 for the Netgem i-Player now supports component output. I have tried this into the iScan Ultra and it works just fine.
    Rob.
  2. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
  3. lscolman
    lscolman
    Jul 31, 2003
    7,145
    Tyne & Wear
    +151
    Rob100,
    What cable did you use to connect the netgem to the iscan?
    Cheers, Lee
  4. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    I tried this a while ago with a scart to component cable into my panny 6. I found the picture was much softer when compared to the straight scart connection. So that's another unused cable in the pile :rolleyes:
    I'd guess an iScan ultra would alleviate the softness, or maybe it's just my setup.
    Cheers, Carl.
  5. Rob100
    Rob100
    Nov 3, 2002
    3,482
    +227
    I used an adapter from Keene and a std component video cable.
    See www.keene.co.uk and do a search for a KA150. Alternatively I think a cable such as their SBB72 would do the trick.
    Rob.
  6. lscolman
    lscolman
    Jul 31, 2003
    7,145
    Tyne & Wear
    +151
    Rob100,
    That was the exact item I was looking at on Keene. Can you comment on the picture quality. I currently have a panasonic freeview box thru a RGB2YUV convertor to an iscan, then onto the panny 4. Are you still using the i-Player, and what is your general impression of the picture quality? You aren't using an iscan by any chance are you?
    Cheers, Lee
  7. philipb
    philipb
    Mar 6, 2002
    2,034
    63
    Swindon
    +149
    I'm using a cheapo Vivanco scart to 3 RCA lead I bought in Sevenoaks (the shop not the town) and was much impressed with the PQ. I now have it connected to a H3DII card for processing, then to a Pioneer 433 and the PQ is excellent. Plan to get a better cable, but even with the cheapy the component out via the PC card is clearly better than scart RGB option on the Netgem .
    The iscan can't do all the H3DII can do but you should see an improvement.
