Netgem i-Player - tell me more
Discussion in 'Satellite TV, Sky TV & FreeSat' started by PhilipVass, Dec 9, 2003.
  1. PhilipVass
    PhilipVass
    So what's this box like...is it anything like the dodgy Bush internet tv adapters a few years ago?
    It looks very good, well the interactive side of it..much more like Sky just wondering if it will be compatible with AOL BROADBAND and will i need to pay extra to use it, is it a one off cost?
    just seen the menus on this website..
    http://www.dtg.org.uk/cgi-bin/www.dtg.org.....html+Receivers
  2. phenom2003
    phenom2003
    Excellent box, the only downsidea are that
    i) it's quite expensive
    ii) it can't view every site (what can you expect for £120 though)
    Very fast through interactive and will almost dfinatly have 7 day epg support, although there is supposed to be a new box coming out soon (although a new one was mentioned for september this year).
    AOL will probably be a problem as usual due to propietry software (could work though), why are you using AOL though? Do you use ADSL or cable?
    Rich
  3. PhilipVass
    PhilipVass
    Do you get free access internet if you have broadband?
  4. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Philip, you don't pay any more for internet if you already have broadband, but it can only access it via an ethernet connection, ie your home network. No knowledge of aol broadband, I take it you've got a BT type 'stingray' modem? If so, you'll need to upgrade to a adsl modem/router, and connect via this, with a USB to ethernet adapter from the list on netgem's website. It does exactly what it says on the tin, there are some restrictions on flash, and streaming media, but it's not too bad.
  5. phenom2003
    phenom2003
    The netgem has a usb connector but no ethernet, you'll need an ethernet to usb adapter dixons do one quite cheaply IIRC.
  6. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    That's what I said, but the cheap Dixons one won't work unless it's on the list on Netgem's website.
