netgem i-player owners.......
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Bill, Dec 9, 2004.
  1. Bill
    Bill
    Oct 31, 2002
    509
    3
    Dungannon
    +32
    Ive heard that this box supports component out, is this correct and through what connection.. ie is it through the scart? and if so where do you buy a scart to component lead?
    Cheers,
    Bill
  2. Emm
    Emm
    Jan 9, 2004
    Norfolk
    Yes, it does support component via the scart.
    For the lead in question try here, though make sure that the 'direction' of the cable is suitable for your needs
    HTH
    :cool:
  3. DJW
    DJW
    Aug 29, 2002
    965
    16
    I bought the lead from Currys/Dixons for only £15 :thumbsup: ...just make sure you ask for Scart to Component.
  4. cerebros
    cerebros
    Dec 27, 2002
    1,190
    38
    Leicester
    +11
    Staff in Currys/Dixons even know what that is? Sure they didn't sell you SCART to Composite? :D
  5. Bill
    Bill
    Oct 31, 2002
    509
    3
    Dungannon
    +32
    Thanks all, youve confirmed what I'd guessed.... just didnt see any in my local stores and was begining to wonder if they existed...
    mmm... one thing though, most searches bring up component to scart, I havn't found any scart to component... wonder if they're two way?
    Cheers,
    Bill :thumbsup:
  6. DJW
    DJW
    Aug 29, 2002
    965
    16
    Ref staff knowledge you are quite correct....I can remember having a debate once over a freeview box over the difference between composite & component :laugh:
    I was quite surprised myself to find the lead in this shop, but there it was labeled Scart to Component & I'm feeding my Netgem box through the component in on my Denon 3805 :smashin:. The cable also appears decent quality.
  7. Bill
    Bill
    Oct 31, 2002
    509
    3
    Dungannon
    +32
    Tried the local currys/dixons with no luck, anyone got a link for an online store with the correct signal pathway ie scart to component? :D
    Bill
  8. DJW
    DJW
    Aug 29, 2002
    965
    16
    Try here for adapter or here for full lead
  9. Bill
    Bill
    Oct 31, 2002
    509
    3
    Dungannon
    +32
    Cheers DJW,
    I have a spare component lead so the adaptor will suit just fine,
    thanks,
    B :thumbsup:
