Netgem / BT box menu advice?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Tenex, Jun 21, 2005.
  1. Tenex
    Tenex
    Mar 2, 2003
    7,632
    +1,063
    Now have the BT box but ISTR that when I had a Netgem it was possible to find stats on the signal strength but can't find it on the BT version - does anyone know if it exists? BBC channels breaking up quite badly the past week and I wondered if it's the signal strength? All others are fine.
  2. rectorydp
    rectorydp
    Nov 15, 2004
    54
    Shropshire
    I don't think any stats are stored but you can get the current signal level from
    MENU>MY ADAPTER>HELP>DIAGNOSTICS>TV SIGNAL
  3. Tenex
    Tenex
    Mar 2, 2003
    7,632
    +1,063
    that's what I wanted - will try it out tonight but I have a sneaking suspicion that the BT box has a different menu. Thanks
