Netgear WN3000RP WiFi Range Extender Review
Discussion in 'Networking & NAS' started by Greg Hook, Nov 27, 2014.
    1. Greg Hook
      Greg Hook
      Moderator & Reviewer
      Nov 25, 2001
      23,511
      2
      In a secret location with Jennifer Lawrence
      +10,473
      Netgear's WN3000RP offers a cost effective solution to extending the range of your existing WiFi network.
    2. TarPot
      TarPot
      Dec 16, 2002
      2,727
      2
      103
      +284
      These are currently £20 on Amazon. I've just ordered one after reading this review.
    3. veno123
      veno123
      Jun 16, 2010
      We've got one in our house, the connection is fast once connected, but often drops for no reason and I have to disconnect and reconnect to the network. The best of the lot but don't expect miracles
    4. Greg Hook
      Greg Hook
      Nov 25, 2001
      23,511
      2
      +10,473
    5. paulmcp2403
      paulmcp2403
      Mar 29, 2005
      1,357
      +142
      I use my phone as a wifi hotspot upstairs ad tether accordingly....I get a solid signal upstairs but poor downstairs....would this help extend it....??
    6. amsquared
      amsquared
      Nov 25, 2008
      17
      3
      Can this be used off an extension lead or does it have to be plugged into a wall socket?
    7. mickevh
      mickevh
      Apr 30, 2007
      6,946
      West London
      +1,620
      It's a Wi-Fi Repeater, not a powerline comms device so it's only using the mains to obtain power, not sending any data over the mains. Thus, you can plug it into anything that will provide power.
      Personally, I would not use repeaters unless there was no other option or I didn't care about speeds. Wi-Fi repeaters have a serious detrimental affect on throughput ("speed") so if throughput rates are a concern Repeaters should be avoided.
      A HomePlug kit (which does send data over the mains) is a better solution if your mains is up to it and speeds are a concern. Using HomePlugs, trailing extension leads can be a problem if they have conditioning filers in them (not all do) - the filters remove the high frequency signals that HomePlugs transmit.
    8. Greg Hook
      Greg Hook
      Nov 25, 2001
      23,511
      2
      +10,473
      I'd agree here. Whilst for £20 (or £15 now) you can't really complain, for the same price you can get a pair of Homeplugs which would be far better. Unless of course you need it for wireless only devices.
      Also, I test all the Powerline adaptors in extension leads too and have not yet come across one that hasn't worked. They don't recommend it, but all the anti-surge ones I have they work fine in.
    9. amsquared
      amsquared
      Nov 25, 2008
      17
      3
      Thanks my mistake.
    10. mikewaltor
      mikewaltor
      Jun 21, 2018
      4
      USA
      Netgear WN3000RP WiFi Range Extender is best device used with wireless router and Its coverage is also wide to use the internet.
