stayingsafe
I have a Netgear DG834G v5 Router
It is setup with Wireless Enabled, but when I try to connect my Windows 7 Laptop to it, it says unable to join network.
I have entered in the correct wifi code, and I have tried connecting other devices (my Kindle and iPhone). The kindle worked today after a few attempts to my laptop and iPhone cannot connect.
I can get to the Router Config Page 192.168.0.1 and login, and can see under Wireless settings that the channel is auto and Mode is b&g.
Enable Wireless Access Point is checked
Security is set to WPA2-PSK but it just wont work.
The router also has something called WPS, not sure what this is.
It works 100% fine via ethernet, and the kinde and another laptop that are connected to it work fine (setup months ago) work fine.
I can see the SSID, signal strength is excellent.
I cannot figure out what the issue is. I have reset the router and still doesn't work.
If anyone can help that would be great. I'm quite IT literate but cannot sort this out.
