netgear or sagem
Discussion in 'Sky Broadband' started by toptinker, Jan 9, 2012.
  1. toptinker
    toptinker
    Dec 28, 2007
    125
    16
    hi been using my oldish netgear router for ages, sky did send me a new one approx 1 year ago but never used it. i usually pull 6mb just thought i would try the new sagem router and it seems to pull 9mb plus it does seem faster. the main reason why i tryed it because the wifi signal is poor even though i have a better antenna fitted and also fitted a powerline wifi signal extender. should i stick with the sagem or stay with the netgear. most people on here think the netgear is far better etc (maybe update the firmware ? )
