Question Netgear GS308 connection with sky
Discussion in 'Computer Components' started by dudeonline, Apr 26, 2016.
  1. dudeonline
    dudeonline
    Oct 2, 2006
    1,739
    63
    Bath
    +189
    I've bought the above an 8 port switch. I've got 1200av powerline adapters and want to make use of their speed internally, so I've got 1 cable from the sky router to the switch then all my other devices are connected to the switch. I cannot get an internet connection for any device. not can my devices see each other.
    I've changed the cable between the sky router and switch TNA. Was working fine with just the sky router, am I doing something wrong or is the switch faulty? Link lights are on and flash occasionally.
  2. dudeonline
    dudeonline
    Oct 2, 2006
    1,739
    63
    Bath
    +189
    Ok, so everything is ok now except the connection between the sky box and the router via the switch. Weird, will try and boot the sky box. I can now see my NAS ok from my PC and internet access is ok. Odd one.. Plus the network speed to the NAS has doubled, which was my original goal, so all good bar the sky box.
