Quantcast
Netflix Atmos Issues and Problems.
Zeusyburger
Reported it...
email to Netflix :-
Problem with all Dolby atmos content when played through Netflix app on Apple TV 4K
The Center dialogue channel intermittently plays through the rear speakers
the sound appears to jump from different speakers
I should not get narrative through my rear channel
This is variable durning multiple viewing a of the same content which confirms this is not as director intended and an actual fault when being viewed
I have compatible leads and equipment as this problem is isolated to atmos content on the Netflix Apple TV 4K
The in built Netflix app on my Sony oled AF9 plays atmos content with no problems
Atmos iTunes content as well as prime atmos content all play perfectly
This problem is with the Apple TV4K Netflix app
Please will you investigate this and look into a software update that will address and resolve the issue
Tccaux
Yes and wanted to push me to Apple...
Reported it...
email to Netflix :-
Thanks !
Tccaux
I spent considerable time with Apple support yesterday and seemed to get some serious attention. Spoke with a senior advisor and he took lots of information. If anyone wants to add to the voices wanting a fix, the case # is 100983348216. Thanks!
Zeusyburger
Thank you so much for your efforts...
FCarp
Hi, I can confirm that I also have the same problem: Atmos in Netflix on Apple TV 4K with Denon AVR-X3600H.
I started noticing it while watching the "6 Underground" movie and then with "The Witcher".
I'm pretty sure this is a Netflix problem and hopefully they'll quickly come-up with an update.
Ironically I wanted to switch to my Xbox One X to properly play Netflix's Atmos content, but as soon as I configure my Xbox to play out Atmos, Netflix stays stuck at 24% while loading Atmos content and stuck at 20% while loading 5.1 content. Everything loads fine when the Xbox is configured to play out Dolby Digital.
It would appear that Netflix has multiple issues with Dolby Atmos...
Zeusyburger
Sorry about your issues, but I’m glad this is being recognised and gaining momentum!
please report this to Netflix and Apple...
customer support was very helpful! Hopefully this get addressed soon!!
Tccaux
Thanks for input Do encourage you to contact Netflix. The more we do the faster we’re likely to get some results.
FCarp
Hi, I've re-read all the posts and could only find an Apple support case #.
Is there a Netflix support case # we can reference when we talk to Netflix support?
Zeusyburger
I wasn’t given a support case reference as such, however similar complaints should build up momentum and acknowledgment of this issue.
I’m just glad I’m not the only one affected
I recon more people are also affected by this issue but may of thought it’s part of how the show is presented or maybe just not caught it...
all things are pointing to Netflix on Apple TV
Tccaux
Thanks for the update
I got email confirmations of my call but no case#.
4kGold
Hello. I have been having this issue with all of my streaming services that have Dolby Atmos (Netflix, Disney+ and Amazon Prime). I have tried so many things to fix it but nothing is perfect or permanent. I am streaming from the Xbox One S and the only way to make it work is to delete the Dolby App and reinstall it every time I use it. It will work pretty well after but there will be at least one 1-2 second cut out per hour episode (the Witcher case-in-point). If I turn the system off it does not work at all upon reboot. Netflix will give me an error message when I try to load Atmos titles. I am thinking this issue has to to with bitrate since I can override that error by loading the titles in 5.1 and then change the audio to Atmos once the title starts. However, it gets super buggy. The video/audio is clear but cuts out every second for a fraction of a second to play catch up. This problem is really frustrating. I have a few 4k discs and Blu-Ray's with Atmos and they seem to work fine.
This problem is super frustrating and I feel like I've tried everything.
Anyone with input would be appreciated.
Thanks.
TCL 55-inch 6 series (Costco model)
Yamaha 6850 receiver (Costco model)
Definitive Technology Pro Cinema 100 5.1 system, sony atmos in the front
tye722
Anyone having any issues anymore. I’ve gone back to watching the Irishman and it hasn’t missed a beat so far. Using Samsung HW-Q90R which had similar problems.
Edit: seems to have come back :(
Rizvan
I am not sure if its worth checking the HDMI cables?
My setup seems to be working perfectly fine....
LG C8 65"
Samsung HW-N950
Apple TV
Panasonic 820 4K UHD Player
Sky Q 2TB (8-bit mode)
Zeusyburger
LG C8 65"
Samsung HW-N950
Apple TV
If it were the cables would atmos iTunes, atmos tv+, atmos prime and Netflix built into the Sony Af9 all present the same issue
the problem only occurs with atmos on Apple TV Netflix app...
My cables all meet specification but still have this problem... good idea though? But unfortunately I don’t think it’s a simple as replacing the hdmi cable
Zeusyburger
I have good days and bad days
my gut feeling is it’s down to variable bitrate secondary to bandwidth fluctuations
reecelouie94
exact same soundbar as you!!! using atmos on my one x i dont have audio channel changes i get audio pops so every so often on 6 underground and the witcher the speakers (through all channels) make a loud pop noise so annoying anyone have this problem i know it aint bar as watched muliple 4k blurays with atmos no problem
Jasenjoberic
Hi all, I'm having exactly the same issue with Atmos on netflix. Using Applet TV 4k connected to a Samsung HW-Q90R soundbar. Periodically the sound channels "jump/funny voices" for a couple of seconds, and then it gets OK again.
Contacted Netflix support service and they are suggesting it might be caused by the internet bandwith... I don't know how to check the bandwidth in Apple TV 4k netflix app.
By the way, I watch Atmos series in Amazon Prime Video and Apple TV+ without any issue...so to me the problem with bandwidth is at least questionable...
gdmerm
experiencing the same issue of sound jumping intermittently between front speakers and surround speakers. Reproducible only on AppleTV4K.
TV: LG C9 55”
AVR: DENON AVR-2500H
Bandwidth flunctuations do seem to be relevant as the problem is very noticeable when streaming and downloading at the same time (but only on the AppleTV4K as already mentioned).
This is definitely an AppleTV specific issue and seems to be related with bandwidth flunctuations. I have not investigated whether it’s a generic AppleTV issue or a Netflix AppleTV issue i.e. whether it’s happening in other streaming apps.
P.S: issue occurs only with Dolby Atmos decoding.
Jrod79
Hello all and great work by everybody here!
I just got an LG C9 65" set and I went to watch "Our Planet" on Netflix when I noticed the ATMOS track sending the center vocal channel to the right rear speaker of my home theater. At first I thought this must be intentional hahahaha. After it doing it for a few mins I said hell nah! There is something wrong here hahaha
My setup is
LG C9 65"
Pioneer LX-801 AVR
Atlantic Technology 270 THX Select Speaker System
Let me know if there is anything I can do to help push this fix along
Zeusyburger
My setup is
LG C9 65"
Pioneer LX-801 AVR
Yeah please report this to Netflix and Apple!! The more people do, the more chance we have of being heard!
DaveTheStalker
My wife bought an AppleTV 4K for my birthday in late November. The first thing I watched was The Irishman. Two minutes into the movie, all of the dialog shot up to the Atmos speakers and rear surrounds! It does it with anything on Netflix that has Atmos; Punisher, Bird Box, The Witcher, etc.
I’ve reported it twice. Both times the CSR wouldn’t just allow me to speak to tech support, they insisted on being the middleman and went down a troubleshooting checklist. The first time, the invisible tech person on the other end refused to escalate it to the software engineering team until I called the SPEAKER MANUFACTURER to have them troubleshoot why 🍏tv+, Disney+, Vudu, and Amazon play Atmos streams perfectly fine, but Netlix has this issue! When the CSR asked me what my internet speed is, she didn’t understand what “25 down” meant! How can you work for an internet streaming service and not know common terminology? Their required speed for the UltraHD tier is just 3 down.
of course, both CSRs claimed this was the first time this has been reported. I posted the link to this thread in a comment on Netflix’s Facebook page. It has still gone unanswered.
The second CSR had me go to the audio settings on the AppleTV and switch the format to Dolby Digital 5.1 (turning Atmos off). She then had me resume playback and asked if the problem persisted. To which I said “no”. The supposed tech support guru on the other end said that the problem is resolved.
Geniuses they are!
gdmerm
Do everybody here who experience this issue have a Dolby Vision enabled Telly? I disabled Dolby Vision and the issue seems to no longer reproduce. This is not a fix. Just an observation.
Zeusyburger
I’ve a Sony Af9 oled with Dolby vision capabilities...
not tried what you’ve stated and suppose this could be an improvement to the overall experience as the sound issue is more annoying than let’s say not having dynamic hdr metadata
cheers for your input
Similar threads
Trending threads
Latest News
High End Munich 2020 Hi-Fi Show cancelled
  • By Andy Bassett
  • Published
Samsung leads global TV market for 14th straight year
  • By Andy Bassett
  • Published
Apple wireless home cinema audio hinted by patent?
  • By Andy Bassett
  • Published
Samsung and BT deliver UK’s first live 8K sports broadcast
  • By Andy Bassett
  • Published
Bowers & Wilkins confirms corporate changes
  • By Andy Bassett
  • Published
