Netbook Recommendations Required Please
Ro5well
Joined
Jan 29, 2010
Messages
97
Reaction score
Points
50
Age
52
Location
County Durham
— As an Amazon Associate, AVForums earns from qualifying purchases —
There seems to be loads the same. Do I just pick one at random and buy it? :confused:
Are they actually any good? :confused:
Yes they are all the same except some have a white lid.
Are they any good - well I have a few - downsides are shorter battery life due to 3 cell battery but you can buy a 6 cell, the 2GB memory upgrade requires some disassembly and the touchpad isn't the best due to integrated buttons but it does support two finger scrolling which helps. At this price it is a good deal and it will easily run Mac OSX but if you are happy to spend more then other netbooks may be a better choice.
Dell Mini 10 Forums - Dell Mini 10v Discussion at MyDellMini
- Simon.
Hmmmm, I'm not sure the the low price justifies the downsides.
I'm not keen. Thanks for your help and advice though. :)
NC10 at dixons
Discount code 10NET
should give you £10 off, but ends 01/02/10 ( code was obtained through quidco which you can also use to get 3.2% cashback if you want )
Delivery is free if I recall
Can't help with regards choosing a model as thats what I came here for :s
Good luck with your choice / purchase
I've ruled out the N130 as IMHO its ugly compared to the NC10 and the Asus Seashell.
Is 4K Blu-ray Worth It?
Back
