Net MD Import MP3, please help
Discussion in 'Headphones, Earphones & Portable Music' started by DaveH, Mar 21, 2003.
  1. DaveH
    DaveH
    Aug 1, 2000
    681
    Surbiton, Surrey
    +20
    I have been checking in MP3's to my NETMD. Very good.
    However, I have a couple of MP3's that will not convert I get:
    OMG only support raw audio of 2 channel, 44.1Khz and 16bit.
    I have tried changing the Import options so it converts it before hand, but it will not import it.
    Any ideas how I can get around this?
    Dave
  2. darthballs
    darthballs
    Mar 4, 2003
    260
    Gravesend
    +4
    Hi Dave,
    I had exactly the same problem and AFAIK you have two options. Either a) re-master your mp3 from the original cd that you ripped it from in the first place using the NetMD software or b) load up the mp3 file into some audio software such as Sound forge (is what I use), Cool edit pro, or wavelab and then save the file as a .wav file and load that into the NetMD software program and viola! Your track should be loaded onto disc no problemo...
    cheers
    darthballs :smashin:
  3. DaveH
    DaveH
    Aug 1, 2000
    681
    Surbiton, Surrey
    +20
    Thanks.
    I'll try and get one of these packages.
    Thanks for the info...
