.Net Framework and my movies plugin
Discussion in 'Computer Components' started by meansizzler, Aug 14, 2005.
  1. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    As i understand .net framework is required for the my movies plugin as well as
    other software, but when I install the .net framework, i get a log on screen each time I boot my computer, is there anyway to disable the log on screen, other than unistalling .net framework, why do you get it in the first place?..also has anyone noticed the media player 10 or my music section in media center being screwed up when installing .net framework, happened to me twice, screwed the napster plugin in media player and media center, kept getting loads of eror messages...
  2. Rambles
    Rambles
    Jul 14, 2004
    8,479
    UK
    +1,355
    If I remember correctly, the .net framework adds a new user account. If you go into User Accounts either via Control Panel, or clicking on start - then the picture next to your name - you can delete this account and/or customise the way users log on and off to your system.
  3. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    Thankyou Lisa, It worked...
