Nest Protect & Part P regs
Discussion in 'Smart Home, Climate Control & Security Forum' started by wokman, May 8, 2016.
  1. wokman
    wokman
    May 8, 2016
    3
    Surrey
    Just installed a Nest v3 thermostat. Now looking at putting in Nest wired Protect CO & Smoke detectors. Since we are doing a major development, we need to get the sparky doing all the electrics to provide us with Part P certificate. In his view, he is not confident that the regs will allow for a smart Smoke/CO. The question is what happens when the wi-fi/Internet is knocked off during a fire?? He has currently installed standard wired Smoke/COs.
    Sorry if this has been asked before. Anyone has any experience in this? Also any leads for getting best deals on a couple of Protects highly appreciated.
  2. snow-munki
    snow-munki
    Nov 29, 2003
    660
    +17
    If there is no internet it won't be able to alert your phone but will still work as standard smoke alarms.
    They have their own WIFI so will still be able to communicate with each other. So if there is smoke in the kitchen all of the other nest protects will alarm.
  3. neilball
    neilball
    Jan 7, 2005
    2,839
    Scottish Borders
    +609
    There are no options for heat detectors with Nest so that may be a problem if you need sensors for kitchens, garages etc
  4. hort2074
    hort2074
    Apr 22, 2016
    1,095
    UK
    +311
    There is no requirement for heat detectors in kitchens, only recommendations. CO detection is also recommended for these areas.
