Nero can't see Pioneer DVR108
Discussion in 'Desktop & Laptop Computers Forum' started by Mark Ward, Oct 1, 2004.
  1. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    Just upgraded to a Pioneer DVR108 but Nero can't see it.
    Nero tools can and report it accurately however Nero it'sself only offers me "Image Copy".
    I'm using Nero 5.5 with the latest patch to the highest 5.5 can go. Anyone got any suggestions?
    Thanks,
    Mark.
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I doubt you'll get Nero 5 to see it, AFAIK device recognition requires updates and Ahead aren't updating Nero 5. The fact that the utilities appear to know what it is doesn't actually mean very much, they're probably just reading standard text strings from the device's firmware, whereas the burner itself needs to know a lot more, presumably an Image Copy is more generic than the other operations Nero performs which I'm guessing is why it can handle that.
    I'm no expert here but unless I'm mistaken you'll need to upgrade to Nero 6 .. I take it you got an OEM version of the 108 without bundled software.
  3. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    Guess I'll be going for Nero 6 then... I did notice that there's a few different Nero6 package options available. Which would you recommend.
    I didn't get the Nero oem with my 108, but I did buy 5.5 and have a full licence key for it so I could go for an online update.
    Cheers,
    Mark.
  4. Embarker
    Embarker
    Apr 19, 2004
    1,676
    Garden of England
    +70
    if you go here
    This patch is region free (RPC-1), has the rip-lock disabled, and also allows you to burn any DVD-R disc at any speed between 6x and 16x.
    I see a little upgrade for me too...... :smashin:
    Happy burning at lease your computer hobby seems less painful than DIY :laugh:
  5. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    That's a very useful patch Dave, thanks. Howver I'll still need to upgrade to Nero 6 to take advantage of it as my drive just isn't recognised.
    Don't actually do that much burning, just needed a DVD-Rom for my new Linux server and as there's so little difference in price I decided to put my old Pioneer 107 in the Linux box and buy a dual layer drive for my PC.
    BT. DIY is a distant (though painful) memory!
    Mark.
  6. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Not sure where you were looking Mark, this upgrade page lists only one upgrade option.
  7. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    My NEC dual layer drive wouldn't work with nero 5, I needed 6.
  8. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    Nero6 cured it!
    Thanks,
    Mark.
