Nero 7 Nerovision problem
Discussion in 'Computer Software & Operating Systems' started by Setenza, Apr 30, 2007.
  1. Setenza
    Setenza
    Jun 17, 2002
    3,349
    +226
    I've been happily using Nero 7 for a while. I use Nerovision to burn videos to DVD. I create a simple menu and then encode and burn to the hard drive of my PC, then to a DVD+RW at a later date.
    Problem is I've started getting random sound sync issues. Sometime this willaffect all video material encoded and burnt, sometimes just some. I'm running the latest version of Nero so I can't just upgrade. I've tried searching through the knowledge base on the Nero website, but it's lousy and has no relevant details.
    I haven't had the fault duplicated on my laptop, so perhaps it's my PC hardware? But if this were so, why should the fault slowly develop and not manifest itself from the first.
    Running a fully up to date XP Professional box with a P4 processor. Only got half gig of RAM though.
    Any clues or similar problems out there?
    Thanks,
    XoD
  2. Member 79251
    Member 79251
    Jul 2, 2005
    13,421
    +2,187
    Can a mod from GC move this to the PC Software & Operating Systems section thanks :smashin:
    Have you tried replacing the media ? as I get major flaws on some cheap dvds :(
  3. Fusewire
    Fusewire
    Jul 18, 2005
    1,617
    63
    +104
    Possibly the DVD burner......
    I had a similar problem a while back, started off as you describe and ended up with the DVD writer packing up altogether. :(
    Got a new one and no probs since. :smashin:
  4. Gadget Daddy
    Gadget Daddy
    Feb 19, 2005
    3,427
    83
    Stockton on Tees
    +174
    bung another harddisk in and try a fresh build of XP and Nero see if that works, if it does rebuild your main disk
  5. Gadget Daddy
    Gadget Daddy
    Feb 19, 2005
    3,427
    83
    Stockton on Tees
    +174
    ps is it OOS on the hard disk before being burnt to DVD?
  6. Setenza
    Setenza
    Jun 17, 2002
    3,349
    +226
    I always get Nero to burn to a folder on the hard drive.
    I then test the contents of this folder using Nero ShowTime and Cyberlink to see if there is a sync issue. The contents being a subfolder (Video_TS) containing the vob and ifo files etc.
    Therefore, it is not the burner or the media (QED)
    This places the problem on the hardware or the Nero software itself.
  7. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    doesn't directly answer your problem but try you should "ConvertXtoDVD" by a french company called VSO. Fantastic cheap app that converts and burns about 3x faster than Nerovision :smashin:
    Output quality is superb and i'm yet to find a format it won't convert. menu's are stupidly simple to create
  8. Setenza
    Setenza
    Jun 17, 2002
    3,349
    +226
    Thanks Uridium, I got a copy of ConvertXtoDVD. It solved all my problems! Very fast as well. Excellent product.
