Nero 6 Problem. Big Dilema!!!
Discussion in 'Desktop & Laptop Computers Forum' started by Stellavision, Jun 17, 2004.
  1. Stellavision
    Stellavision
    Apr 7, 2003
    2,400
    Southsea, UK
    +102
    I bought the latest Nero 6 suite this week and the power pack bundled with it has some great software. However, I have a major dilema.
    I backed up a load of files using the create a data disk option onto dvd.
    Like a fool I didn't check afterwards and went ahead with a hard drive reformat.
    Now when I put the disk in I can see all my files, roughly about 3 gig of data, but none of the files work. I have precious photo's stored on there but when I click on it Microsoft picture viewer opens and says 'no picture available'.
    Exe files don't even execute and document files don't open.
    There must be a way to access these files, I can't have 3 gig of nothing, can I?
    Please help!!!! :lease:
  2. Kramer
    Kramer
    AFAIK compression is selected by default with Nero "Back it up". You'll probably have to uncompress again using Nero to access your data.
    :smoke:
  3. Stellavision
    Stellavision
    Apr 7, 2003
    2,400
    Southsea, UK
    +102
    I don't think I used the backup option. I used the create data disk optionbecause it seemed more practical than compressing files etc using the backup utility.
  4. The Dude
    The Dude
    May 21, 2004
    6,403
    Beverley, East Yorkshire
    +2,788
    just as a quick test try copying some of the files back to the hard drive ans try opening them from there... does it let you copy the files? do they open ?
  5. Stellavision
    Stellavision
    Apr 7, 2003
    2,400
    Southsea, UK
    +102
    Done that, does not work! Copied a 379Kb bitmap image from dvd to c: and still the same. :mad:
  6. The Dude
    The Dude
    May 21, 2004
    6,403
    +2,788
    rather than double-clicking on files to open, try file >open in picture viewer, and browse for the file.... see if it opens this way..
  7. Stellavision
    Stellavision
    Apr 7, 2003
    2,400
    Southsea, UK
    +102
    Already tried that, no luck.
  8. The Dude
    The Dude
    May 21, 2004
    6,403
    +2,788
    is it just the files on the DVD you're struggling with?
    if you create a new word doc etc, then save it, can you open it up again?
  9. Stellavision
    Stellavision
    Apr 7, 2003
    2,400
    Southsea, UK
    +102
    Yes, only files on the dvd.
    I made 2 or 3 dvd's at the same time and I can access my files with no problem on the others. When I try and open files on this dvd in nero I get the message, "Unexpected file format"
  10. Kramer
    Kramer
    Are the files showing properly in properties, .doc, .jpg etc?
  11. Tim Cooper
    Tim Cooper
    Sep 20, 2000
    2,858
    71
    Laindon Essex
    +96
    Barrie,
    What is the file format stored on the dvd?
    Tim
