Neovia NEO3775ND
Discussion in 'LCD & LED LCD TVs' started by busdriver2000, Jun 5, 2005.
  1. busdriver2000
    busdriver2000
    May 22, 2005
    79
    harrogate
    Has anybody seen one ? are they any good ?
  2. peahead
    peahead
    Dec 14, 2002
    2,843
    St.helens
    +277
    link would help
  3. deeplyblue
    deeplyblue
    Jan 28, 2005
    332
    +18
    Currently a lead item on Curry's homepage
    http://www.currys.co.uk/
    £1499
    not seen.
    db
  4. snoods
    snoods
    Apr 26, 2005
    272
    Kilwinning, North Ayrshire, Scotland, UK.
    +33
  5. azim
    azim
    Mar 7, 2005
    76
    I think they got them on sale at curries....looked really really soft compared to the other lcd screens near it (with the same feed)
  6. stephen8363
    stephen8363
    I bought one of these from Currys on a £1499 deal which included an LG DVD recorder and a stand.
    I was a bit sceptical at first, having never heard of Neovia, but after a couple of weeks of owning one I would not hesitate to recommend one of these TVs - picture and sound quality is excellent, and all the connectivity you could need is there (DVI with HDCP, component, 2 x scart, optical, PC D-SUB, s-video).
    The only small negative is that this model looks slightly clumsy when compared with the Panasonics, Sonys, etc but I can live with this when thinking of the quality & features you get for the price. :thumbsup:
  7. RockySpieler
    RockySpieler
    May 23, 2005
    1,659
    Snaking the Lineup
    +116
    stephen8363
    I notice you mention "Optical", is this Optical Digitial Sound IN?
    Have you tried it, do you know how does that work (it has side speakers, on the web photos)?
  8. stephen8363
    stephen8363
    Hi RockySpieler,
    The optical connection on the TV is an output, I have tried it through my surround sound system and it sounded pretty good.
    There are two audio inputs on this set, one using a single jack connector and one using L&R phono connectors.
    The deal from Currys is pretty good for the TV and the stand, though the spec of the LG DVD recorder is very basic, and I have since sold it on & replaced with a higher spec Panasonic unit.
