Neovia NEO3775ND @ Currys
Discussion in 'LCD & LED LCD TVs Forum' started by hamd01, Jun 6, 2005.
Tags:
  1. hamd01
    hamd01
    Mar 21, 2005
    959
    46
    Cumbria
    +145
    Has anyone had a good look at this set? Seems a very good price at £1,500!
    Is it actually 16:9 or 15:9, how is the picture quality, does anyone actually have one and can post a review?
    It doesnt have a HDTV ready sticker..... so is it? The Currys staff seemed adamant that it is HDTV, but I'm not sure? They said if a set has a DVI port it is HDTV ready..... is that just HDTV compatible, or is that able to display HDTV at its full potential?
    David.
  2. snoods
    snoods
    Apr 26, 2005
    303
    Kilwinning, North Ayrshire, Scotland, UK.
    +64
  3. hamd01
    hamd01
    Mar 21, 2005
    959
    46
    Cumbria
    +145
    But I understand the resolution given in the specs isnt actually correct. There also isnt any comments from an owner in those threads, hence this new thread.
    David.
  4. snoods
    snoods
    Apr 26, 2005
    303
    +64
    Why isn't the resolution correct? All new LCD TV's appearing seem to be WXGA 1366x768 16:9 format now aren't they?
    Hope you can get some feedback soon then althought you may have to wait a while as this TV is just out.
    You could always pop into a Currys or Dixons to verify the resolution. :)
  5. hamd01
    hamd01
    Mar 21, 2005
    959
    46
    Cumbria
    +145
    It may indicate 16:9 on the specs, but Im pretty sure its actually 15:9. Could someone confirm?
  6. lee01
    lee01
    Feb 5, 2005
    151
    aberdeen
    its a good buy. i set it up at my work pic quality is pretty good cant go wrong for 1500. the only thing im not to sure about the sound its a bit plain but if uve a surround kit. then theres no probs :)
