Neo 6 or PL 2 with 7.1 set up?
Discussion in 'AV Receivers & Amplifiers' started by Jules, Aug 18, 2002.
  1. Jules
    Jules
    Oct 11, 2000
    5,633
    134
    +1,121
    I understand that Neo 6 was designed to make use of the additional back speakers in a 6/7.1 set up, whereas PL2 was designed for a 5.1 system.
    I know most people say PL2 has the edge over Neo 6, but does this still hold true with a 7.1 set up?
    With my upgraded AVC-A1SE, I usually have all 7 speakers running with both formats. Is this wrong?
    In line with THX Ultra2 specifications, I’m using dipole side surrounds, and monopole surround backs.
    What do you think?
    Jules
  2. Jase
    Jase
    Mar 16, 2001
    10,742
    United Kingdom
    +2,531
    PL2 is very good indeed, I prefer it to DTS Neo. But like you mention, the advantage of DTS Neo is it gives you 6.1/7.1 on the A1SE. You can leave the surround backs on for PL2 as it does´nt actually produce any sound out of them, the default mode is "Normal" with the surround back light indicator on the amp switched ON. Stick your head by the surround backs and you won´t hear anything though. If I remember rightly you can also switch the mode for PL2 and get some output from the surround backs (Matrix On).
    Just leave it set up to how you want it.
    Cheers:)
  3. Jules
    Jules
    Oct 11, 2000
    5,633
    134
    +1,121
    Thanks Jase.
    I think Denon need to fix the interface in this regard, it can be quite confusing.
    I had noticed that in the 'normal' setting the surround backs are not on during PL2, but the surround back light still comes on.
    I just wondered what other people do with their PL2 / Neo 6 options in a 7.1 set up.
    Jules
