Neighbour worries
Discussion in 'Home Cinema Speakers' started by Finty, Feb 4, 2002.
  1. Finty
    Finty
    Hi folks
    Is there anything I can put under my sub (from KEF KHT2005 package) that will prevent excess 'thump' from annoying my neighbours downstairs?!!
    Fin
  2. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    Only a detached house.
  3. Finty
    Finty
    Thanks Pointon -
    but if I put a detached house under my Sub won't I be back to square one again?
    Constructive replies anyone?
    F
  4. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    Sorry, was a bit short.
    But really there's not much you can do about it. It's not just the space under the sub that you need to worry about. With this type of sound it's the floor, walls, ceilings. Try a lot of carpetting, rugs and the like. It won't have much effect, but it's something. You could always put your sub on a concrete block or slab if you don't want it directly on the floor.
  5. BadAss
    BadAss
    Feb 2, 2001
    2,967
    England
    +182
    I wouldnt usually suggest this in a normal living room but I would put laminated flooring down. This will reflect the sound into the room instead of it passing through your floor boards below. Thats if you have floor boards. If you live in a flat with concrete floor there aint nothing you can do. Apart from create a false floor, but if your renting you wouldn't want to pay out for it. Basicly mate your boll*xed.
  6. BadAss
    BadAss
    Feb 2, 2001
    2,967
    England
    +182
    I live in an end terraced house so I only have one nieghbour to worry about. Basicly for me having nieghbours means listening at very low levels at night or full blast in the afternoon when they are hopfully out and the misses is at work. I'm afraid a compromise is needed in your case aswell.
  7. paiger
    paiger
    Try moving to an area where all your neighbours are deaf or insane, or both.
  8. Finty
    Finty
    Think I'll buy a slate slab while I save for a house way out on a moor...
  9. S H A D O
    S H A D O
    Mar 16, 2001
    10,374
    United Kingdom
    +1,753
    Luckily for me, I already do!:D
    Not that Insanity rubs off on you, does the chicken wax its legs with grounded parmesan??
  10. Finty
    Finty
    ...and does it wonder why the human crossed the road?
    Argh - the insanity was catching. Time to annoy some neighbours!
  11. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    i had the same problem with my neighbours as well, however a sort the problem out by moving the sub to another side of the room (not that that will help you as you live in a flat) and sticking £40 worth of isolation feet (made by perfect sound - bought from norman h fields in birmingham city centre) underneath the sub.
    I did this at the beginning of october and i've not had one moan since - and i've watch some VERY VERY loud movies.
    so either the neighbours have lost their hearing or they cant hear it.
    Gary
  12. Finty
    Finty
    Cheers Gar
    Could you give me more details about these 'isolation feet' - what are they exactly, is there a website I can get em off etc.
    For anyone else - would putting a slate slab (or something similar) under the sub be of any value at all?
    Finty
  13. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    Hi Finty,
    I'm sorry but the best i can do is give you Norman H Field's phone number 0121 622 3619, they were/are part of the "Hi Fi markets" chain. I think the feet were about £5 each, so i bought 12, 4 for each of my front speakers and 4 for the sub, (my rears were already on spiked stands) they made the world of diffrence to the sound of my system (even my wife noticed the difference!!!). while the sound became for focused the sub lost alot of the undisrable boom.
    I've just had a look around the web and found the following:
    http://www.hometheatermag.com/showarchives.cgi?68
    "And don't forget those brass cones. They reduce vibration against the floor, which could turn the sound into a muddied mess. The feet provide a critical service, elevating the sub sufficiently to give the bottom vent the room it needs to exhale. Isolation cones have long been thought to have magical powers, a tweaker's fetish, in reducing vibration and enhancing the clarity of all things electronic. The cheap plastic spheres included with the average budget sub just don't do the trick. I recall one company that offered an otherwise-excellent subwoofer costing about $100 more than the AC Sub 100, but the designers didn't even leave holes for the plastic feet. They packed the feet and metal screws in a bag with drilling instructions for the holes. That experience made my discovery of Pinnacle's brass cones even more pleasantly surprising."
    while this stuff does not relate to the isolation cones i bought, it does demonstrate that they can and do work
    There was also some stuff on www.pinnaclespeakers.com
    I've just spoke to Field's and they told me that they get them through a company called "vedaproducts". while they couldn't give me a web address they did give me and email address info@vedaproducts.co.uk the products you are after info on are "Perfect Sound, Isolation Cones"
    I really hope this helps, as i know how frustrating it can be, if i can help again then please let me know.
    Gary
  14. Finty
    Finty
    Gary
    That's a fantastic help. Thanks very much pal, especially for ringing the suppliers of the feet for the email address. As we say in my part of the world "good man yerself"
    I'll get on to Veda Products directly!
    Thanks again
    Finty
  15. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    No problem at all, just remember that help when i show up on your door step at two in the morning blind drunk and looking for somewhere to lay my head!!! ha ha
    Anyway, happy to help, let me know how you get on.
    Gary
