Neff sell a warming drawer to match their hide and slide oven range. They are surprisingly useful and work well (for a time). The model is Neff N17HH11NOB (140mm high) and the larger N17HH20NOB (290mm high).
Mine failed after 3 years and was going to cost probably around £150+ to repair by Neff (£99 labour/call out plus parts on top). There seem to be many owners who suffer from a similar failure, Neff's own website does not make good reading , have a look N17HH11N0B
The problem with mine was that the red light kept flashing when the drawer was closed and only a small area of the hot plate (rear right hand side) got at all warm (by the fan heater which is in the side of the unit). The fault turned out to be with the power connector at the rear of the pull out drawer which was failing. It's basically a kettle connector for cordless kettles. The control module will not connect power to the drawer unless it detects it's closed. When the connector begins to fail the hot plate will not get warm as the power controller thinks the drawer is open.
Replacements are available from here 00612218 or ebay Bosch Neff Siemens Coupling 612218 | eBay
Relatively easy to fit but do not attempt unless you are competent. The whole device has to be removed as both parts of the power connector need replacing. The drawer itself is easy to remove, just remove the two screws from inside the drawer (one each side) and the drawer can be lifted out.
On the main unit the connector is fitted inside the panel on the rear (two screws).
