DVD only code change.
BabyZ CD-R hack
LG BP540 region free code information and comments.
www.videohelp.com
1) Create a folder: Violet0000
2) Inside /Violet0000 create a subfolder: Rubicon
3) Download the MontBlanc.txt file here:
https://www.avforums.com/attachments/montblanc-
txt.873684/
4) Save it in the Rubicon folder as a .dvd file called MontBlanc.dvd (note: DO NOT save it as a
text file. Change the file extension. If you cannot see the file extension, select "All File
Types" on the extensions tab of the download window)
5) Your folder stucture should be like this: /Violet0000/Rubicon/MontBlanc.dvd
6) Drag and drop the Violet0000 folder (/Violet0000/Rubicon/MontBlanc.dvd) to your prefered CDR
burner software.
7) Insert the CDR into your player. A black menu screen will appear with the current region
code and a place to select a new region code. Select 0 for universal region.
PS.: If you can't download montblanc-txt file from the link above, try the link below:
MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 50GB now
mega.nz
I suggest using BabyZ's
mega.nz
and unzipping the file into a folder then copying the folder /Violet0000/Rubicon/MontBlanc.dvd on to a blank cd-r.
It worked on my BH9350TW! Well done BabyZ!
mega.nz
