Needed Desperatly. VOIP recording software
Discussion in 'Apple Forum' started by Someguy, Sep 11, 2007.
  1. Someguy
    Someguy
    May 8, 2007
    558
    +4
    Doing a podcast in around 30 minutes, thought I had software which would record the entire conference including me.
    Audio Hijack does not seem to do that. Anyone know of any?
  2. rob_finch
    rob_finch
    May 8, 2005
    791
    43
    +94
  3. terryxpress
    terryxpress
    Sep 1, 2006
    24
    3
    +3
    http://www.freeverse.com/apps/app/?id=5012
    is for SoundStudio, which you may wish to check out also. Costs more than the other software suggested, but the interface and features are second to none - I think it is far better than others like Audacity etc.
  4. jont
    jont
    Apr 8, 2002
    4,335
    near Aylesbury
    +577
    If you have to do it again then this looks like the only software that will do multi-input recording at the same time - and allow you to independently edit them after !!
    http://www.macrumors.com/2007/09/13/exclusive-preview-ambrosia-softwares-wiretap-studio/
    The other cool thing is a real-time compression/conversion feature that allows you to hear the difference in levels ... and a 'non-destructive' kind of export that keeps the original file in the background somewhere ...
    Jon
  5. Someguy
    Someguy
    May 8, 2007
    558
    +4
    Hey Guys
    The links worked fine. I used the first suggested. Been off for a while, just wanted to say thanks anyway. So Thanks !!!
