Need XP driver for ATI Mobility Radeon 9000
Discussion in 'Desktop & Laptop Computers Forum' started by geordie_blerk, Jan 8, 2004.
  1. geordie_blerk
    geordie_blerk
    Feb 16, 2002
    39
    I've just re-installed XP Pro on my laptop, which uses the above video subsystem, but after re-installing it doesn't recognise the graphics correctly and I can't find any setup CD's with a driver on it.
    I've checked both ATI's and the laptop manufacturer's (Advent) websites but I can't find a driver anywhere.
    Can anybody point my in the right direction?
  2. dUnKle
    dUnKle
    Jan 1, 2001
    15,280
    +2,279
    Was under the impression this was a one driver does them all thing
  3. dgc
    dgc
    May 1, 2003
    216
  4. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    Yes the latest cat drivers will be fine if the ones that load automatically with the xp install aren't.
    My laptop has the same chip and its fine with the xp install, then do windows update for thje latest "approved" version.
  5. geordie_blerk
    geordie_blerk
    Feb 16, 2002
    39
    Thanks for all of the suggestions.
    I had already tried the catalyst drivers but it came up with a message saying it couldn't find any ati devices.
    I've downloaded the specific mobility driver from the link supplied by dgc but that also complains about no ati hardware.
    I think my problem is some sort of chipset configuration problem, it's using a SiS 650 chipset and device manager within XP reports an unknown video device.
    To be honest, I can live with it for now because XP is still letting me run in 32bit colour at 1024x768, which is all I would be running at anyway.
