Need Wireless Broadband help
Discussion in 'Networking & NAS' started by FurryBiggs, Dec 20, 2006.
  1. FurryBiggs
    FurryBiggs
    Hi, i have wireless BT broadband and it is very fast but everytime my phone rings which is wireless aswell the broadband cuts off, does anyone know what i could do to counter this problem
    cheers
  2. sinizterguy
    sinizterguy
    May 19, 2005
    1,007
    48
    +47
    Is it your wireless cutting out or your internet connection ?
    If you dont have a microfilter on every device connected to a telephone socket in the house, the internet will cut out every time a call happens. The wireless connection to your router will still be good, you just wont have internet.
    Just use microfilters.
  3. Member 79251
    Member 79251
    Jul 2, 2005
    13,421
    +2,187
    You need another filter on the line. Same thing happened at a friends house the other night when I did a new install.
  4. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    Spaghetti Junction (really)
    +1,922
    Sounds like they're running at the same frequency.
    Bit awkward, I guess what you need to do is make the internet signal higher the phone signal. You might achieve this by moving your phone further away from your computer/ router. Perhaps you can change the frequency the phone runs at (it might be switchable?).
  5. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    +1,922
    Ah yes, good one :smashin:
  6. Member 79251
    Member 79251
    Jul 2, 2005
    13,421
    +2,187
    This did fix the same problem as posted. 2 lines pre installed in the house. 1 phone box upstairs that ran to a box near the window and the main point down stairs.
    Computer upstairs on the phone point with no phone installed as got DECT phones that are plugged into power socket.
    While browsing the internet the phone went, all the lights went on the box. As soon as call finished lights back on. A filter installed upstairs and downstairs fixed it.
  7. FurryBiggs
    FurryBiggs
    Thankyou very much seems to be working perfectly now even when the phone rings!
