Need urgent advice on ear phones for i pod.
Discussion in 'Headphones, Earphones & Portable Music' started by steeve, Feb 5, 2005.
  1. steeve
    steeve
    Dec 15, 2003
    20
    My ears must be a funny shape as I cant get seem to get any of the standard earphones to hold in my ears. I only have to move and they fall out. I have seen people joging and working out with earphones in. I do have some Phillips ones that fit around the ear but the quality is pretty poor and they look crap.
    Any one recommend some good earphones that will stay in? Help much appreciated.. :lease:
    STEVE..............
  2. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,215
    83
    Over the Hill & Far Away
    +135
    How much do you want to spend ? if you have the budget check out etynomics and shure canalphones.. ranging from £60 - £300ish
    Matt
  3. scrapbook
    scrapbook
    Jan 12, 2002
    7,411
    +550
  4. mick's cat
    mick's cat
    You could also try the Griffin Earjams:
    http://www.griffintechnology.com/products/earjams/
    which are just clip-on adaptors for your existing earbuds. They don't improve the quality of the earbuds, but just convert them into canalphones. They're cheap too...
  5. Tejstar
    Tejstar
    Dec 4, 2002
    22,797
    London
    +1,080
    I use Sennheiser PX-100's and they're thoroughly recommended.
    They're cheap too, retailing for around £30!
  6. ipodstudio
    ipodstudio
    steeve, try browsing this gallery of earbuds to see what's out there. How much are you looking to spend on these?
