Need TV Recomendation
Discussion in 'TVs' started by annefromuk, Dec 5, 2001.
  1. annefromuk
    annefromuk
    I am getting an Xbox imported from the US
    At the moment I only have a 14" TV which probly is not NTSC compatible, so I want to upgrade to a larger TV that can display NTSC signals.
    As I will be spending most of my money on the Xbox, I will need to get a 21" (or 28" Widescreen) at the lowest price possible.
    Does anyone have any model they recomend?
    And where is a good place to get a low priced TV?
    Thanks :kisses:
    Anne
  2. kirk grubb
    kirk grubb
    Sep 6, 2001
    566
    +9
    I would recommend wharfdale 28" from tesco's,about £240.
    Grundig or goodmans widescreens off the net - try unbeatable.co.uk, empire direct .co.uk. About the same price as the wharfdale.
    Hope you have lots of fun with your xbox, i cant wait till i get mine in march.
    I've just bought a ps2- i really couldnt wait !
    Got crash bandicoot with it and not too impressed. Not that much better graphics than the ps1 versions, and the loading times are absolutely shocking !!
    Think i should have waited after all.
    Hope the tv info helps.
    Regards kirk.
