Need to replace pioneer, can any one help?
Discussion in 'Blu-ray & DVD Players & Recorders' started by GalacticaActual, Sep 1, 2005.
  1. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,604
    Galactica C.I.C.
    +199
    Evening all :)
    At the momenet I have a pioneer 757AI dvd player. I am looking to upgrade to a DVD recorder/ hard disc recorder.
    Now the problem is I would like the new player to have the same audio out specs as the 757ai. It needs to have six channel analog audio out to connet to my existing amp which has 6 channel discret audio in via 6 difrent phono leads.
    Can any one recomend a subtable player recorder please?
    It also hasto be multi region and have componenet out as well.
    Many thanks.
    Dave.
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,604
    Galactica C.I.C.
    +199
    No one? :D :hiya: :)
  3. Gary D
    Gary D
    Jan 9, 2002
    7,770
    +826
    Morning Dave i'm not sure there is one mate.
    Oh and you missed prog scan from the list :D when i bought mine about 4 months ago i bought a E85 and kept my Pio 575 because i couldn't find anything to thatcould replace it AND offer recording functions. Am i big fan of DVD - RAM and time slip is :clap:
    you may find you have to keep the the 757 and look for a recorder.
    let me know if you want some research done and i'll have a look over the weekend.
    Gary
  4. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,604
    Galactica C.I.C.
    +199
    Hi Gary :)
    To be honest I had a feeling that such a player did not exitist.
    Will probably go the seperate recorder route after all.
    Cheers :smashin:
  5. laser
    laser
    Aug 1, 2004
    924
    Hartlepool
    +28
    Are you wanting 6 channel input to decode DTS/Dolby digital or to output multi-channel SACD/DVD Audio to the amp?
    Does you amp have firwire input?
