Need to replace lamps in rear-projection TV's too?
Discussion in 'Televisions' started by LaTiNo, Aug 27, 2004.
  1. LaTiNo
    LaTiNo
    Aug 19, 2004
    39
    Is it necessary to replace the lamps used in rear-projection TV's after xxxx hours like you need to with front-projectors?
    TIA
    Gabriel
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,789
    Somewhere in South Yorkshire
    +4,984
    Depends on the technology. RPTVs can be
    - 3 x CRT in which case there are no bulbs, just tubes. These do age and may need replacing but are typically long-lived. They may suffer phosphor burn if subjected to constant display of logo or other unevenly bright images.
    - LCD and DLP these do have bulbs, which do need replacing from time to time. (typically 2000 hours' use or so, but vary by manufacturer). But neither of these will suffer from any permanent damage from excessive brightness etc.
  3. Mad Mikeyboy
    Mad Mikeyboy
    Jun 23, 2004
    356
    Renfrew
    +12
    Having recently bought a DLP RP , And having a wife who watches it constantly, I am worried the lamp wont last long. Is there anywhere these lamps can be bought on the cheap???
