hi,
I am quite new to this and you guys really help when searching forums but I cant find the answer to my problem. I have just bought the onkyo 674e receiver but am struggling with what to connect to what here is my setup:
HDMI 1 - Sky HD
HDMI 2 - Want to leave for PS3
Component 1- Xbox 360
Component 2- Ideally want my pc here is this poss?
Component 3 - Poss DVD
S-Video - Nintendo Wii
Here are my main prohblems:
PC - I dont want to waste a hdmi slot on this, it is good enough to run hd material and graphics card has DVI out (ATI XT800 i think?). The issue is if i connect PS3 via component do i lose anything in performance (heard something about HD sound)? If not I can get a dvi to hdmi to connect my pc
Wii - It is connected via standard cable, will i improve picture by buying the component cable, the manual says my amp should convert 480i to 480p isn't this what the cable does? therefore pointless me getting it as i am seeing best results already??
I am learning quick but it is a lot to get your head round!! I want to fully utilise my setup so any guidance on where i am going wrong or what i may miss out on would be greatly appreciated
HDMI 1 - Sky HD
