Foebane72
A couple of years ago I bought a nice set of LED Christmas tree lights and for the first Christmas all seemed fine. Then, at the end of the second Christmas I noticed that the socket for the lights (which is in the adaptor itself and the lights plug into them) became damaged. Basically, the plug for the lights is female and the male socket in the adaptor is broken so that the pin is loose, so it's a bad contact.
Putting aside how this could've happened - I didn't jolt the lead or anything - I am wondering how easy it is to replace the adaptor, as there's nothing wrong with the lights themselves.
The adaptor is marked:
Safety Isolating Transformer
PLU 264668
Model Number: YMAA-2400200
PRI: 220-240V AC 50Hz
SEC: 24V AC-200mA, 4.8VA
IP:20
Having a look on Amazon, there seems to be plenty of such adaptors, but the "SEC:" values don't always match the ones I have. A lot of them say 24V, so is that enough? What is the risk if the mA figure is much different? Or the VA?
I was thinking of looking at Argos or even Clas Ohlson in town today and see if they have anything, but what do you suggest?
PLU 264668
IP:20
