Need Subwoofer Amp Suggestion for Rockustics SubSub 15
Humdinger
Hello,
First time poster here and audio novice.
I have a Sonos home audio system with six outdoor speakers (2 Bose Free Space 51, 2 Definitive Technology AW 5500, and 2 Polk Atrium 6), all run with amps sourced through Sonos Connects.
I got a good deal on a Rockustics SubSub 15 (specs below), and want to add it to my outdoor arrangement with another separate Sonos Connect and amplifier, but I'm having a really hard time finding the right amplifier (powerful enough with an integrated crossover). The closest I can find is the Dayton SA1000, but it doesn't have a volume control.
Does anybody have any suggestions? Thanks so much.
Nominal Impedance 8 ohm
Impedance (min) 8.0 ohm
Sensitivity dB @ 2.83V/1M 87.0dB
Sensitivity dB @ 1W/1M (2) 87.0dB
Frequency Response (± 3 dB) 27 Hz - 110 Hz
Frequency Response (±10 dB) 25 Hz - 150 Hz
Max. Program Power 700W
Max. Continuous Power RMS 350W
Max. Power SPL @ 1 M 112.5dB
Transducer - Low Frequency Driver 15" Polypropylene
Colors Brown
Inputs Wire lead
Height (SM = Height) 787.4 mm / 31"
Diameter (SM = Width) 482.6 mm / 19"
SM Depth (Including Bracket) 990.6 mm / 39"
Weight 57.3 kg / 126.3 lb
Shipping Weight 68.0 kg / 150 lb
Regulatory - CE approved
Applications
The SubSub 15 is perfect for outdoor areas where you want powerful bass. Use it in themed entertainment, resorts, parks and large gardens.
