Need Stylish, High Quality BLACK Wooden AV Stands?
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by Mahdi, Dec 5, 2004.
  1. Mahdi
    Mahdi
    Any one knows where I can get a High quality/stylish Piano Black AV Stands. It needs to hold down approximatly 4 Devices and also have space for a Front SPEAKR?
    Any ideas :lease: ?
  2. Knightshade
    Knightshade
    Aug 6, 2004
    1,971
    +43
    Are you after Black wood or Black wood effect?
  3. Mahdi
    Mahdi
    Probably Black Wood Effect, unless the Black wood is of a very high quality.
  4. Knightshade
    Knightshade
    Aug 6, 2004
    1,971
    +43
    Have you thought about getting a carpenter to make you one? It's not as expensive as you may think. Laminated MDF would be good unless you're feeling flush in which case I would recommend Ebony....;)
  5. bobbypunk
    bobbypunk
  6. Mahdi
    Mahdi
    Thanks for the info, I like the Spectrals Range but all the Shelfs are more like drawesr and won't allow AV Equipment i.e. AMP and DVD Player to sitt on it.
    Any other suggestions?
  7. bobbypunk
    bobbypunk
    www.standsunique.com
    Not clearly documented but there stands are available in black ash.
    either cabinet fronts or open and fantastic quality.
    The best thing of all is the fact their are prices on there to!
