Need step-by-step guide to Sky+ disk upgrade
Discussion in 'Sky Digital TV Forum' started by NicolasB, Jan 5, 2003.
  1. NicolasB
    NicolasB
    Oct 3, 2002
    5,876
    Emily's Shop
    +566
    Thinking of putting a larger hard disk into my Sky+ box. I'm quite comfortable messing around inside a PC, but I'm not familiar with the innards of a Sky+ unit. Is there a nice, detailed, step-by-step guide to the procedure?
    Also would welcome comments on the choice of hard disk. I thought maybe a Maxtor DiamondMax 16: it's 5400 rpm (I've heard Sky+ can have problems with 7200 rpm disks because of spin-up time), not hideously expensive (£120 for 120GB), and runs fairly quiet - not as quiet as a Seagate Barracuda V, but quiet - and runs unusually cool as well.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Should be of some help........
    Hummer
  3. Messiah
    Messiah
    Apr 22, 2002
    7,529
    +339
    Bit easier than upgrading a TiVo then :D Thanks for the link. May be doing mine shortly.
  4. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Ive gpt a 120gb maxtor 7200 in mine and Ive had no problems at all now after 3 months.
    Its not at all difficult to do the swap, you do need a torx security bit driver (the one with the hole inside a 6 sided star shape). As soon as you take the lid off the Sky+ box you will wonder what your worrying about, just set the new drive to the same jumper settings as the one that comes out and bung it in, turn it on and it sorts itself out.:cool:
  5. Timmy B
    Timmy B
    "120gb maxtor 7200"
    Do you have a model number or a link?
    Many thanks.
  6. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
