Need Speaker stands for my DAVS 550 - anyone know which ones i need?
Discussion in 'Home Cinema Buying & Building' started by Neiliboy, Aug 14, 2005.
  1. Neiliboy
    Neiliboy
    May 13, 2003
    205
    16
    Cambridge
    As the thread titles states really......
    I've had my Sony DAVS 550 for years now but i finally need the speakers stands for it - u know the really thin ones. Does anyone know the model number or where to buy some (or even any aftermarket makes?)??
    Thanks in advance
    Neil
  2. goatboat
    goatboat
    Hi Neiliboy,
    i have same system but have mounted my rear speakers on simple telescopic stands that i bought from one of the big electrical stores. The stands are not sony's own but fit perfectly well.
    perhaps you can help me with my problem - see my thread !
    tim
  3. RobsterD
    RobsterD
    Dec 11, 2000
    891
    Southampton
    +12
  4. k4mmy
    k4mmy
    Oct 31, 2003
    30
    Ive got the same system and I bought some Alphason AD100s
    http://www.appliance-direct.co.uk/more_details.asp?IntID=435&Manufacturer=Alphason&Code=AD100-S.
    The base is made out of glass hence they are a bit pricey but they do look nice on a wooden floor.
    They are universal fitting and will fit most popular speakers even the Sony Pascal ones!
    Kamran
