need speaker advice for 5.1 setup
Discussion in 'Home Cinema Speakers' started by Ewok, Jun 10, 2001.
  1. Ewok
    Ewok
    I am looking at getting a Yamaha DSP-AX620 amp as part of my home cinema setup and need a set of 5.1 speakers to go with it.
    Can anyone suggest the best sub £750 5.1 speaker setup that I can get. It will be used mostly with my DVD player but also for the odd cd. The room is fairly small at 3.5metres by 5.5 metres so I dont have huge space but I do have room for floorstanding fronts, although the rears will have to be wall mounted.
    Thanx
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    The usual suspects
    On a budget: Tannoy Mercury / Mx Series (M3, Mc, M1)
    Close to your budget: Acoustic Energy 100 series (109, 107C, 100i or 101)
  3. ZZR
    ZZR
    Try the Mission FS2's.
