need some urgent help from any z3 owners!!!
Discussion in 'Projectors, Screens & Video Processors' started by seka1980, Jul 18, 2005.
  1. seka1980
    seka1980
    Mar 15, 2005
    125
    +12
    ive just got my sanyo z3 today and ive gota say im blown away by the picture, but i have 1 little problem, i think i may have made a mistake on buying this screen!!
    it does not seem to have horisontal keystone corection , only up and down!
    i take it this means i cant have this projector at the side of my room!!
    is this correct?
  2. seka1980
    seka1980
    Mar 15, 2005
    125
    +12
    oh and 1 more thing wheres the cheapest place to get a wall ceiling mount
  3. cyberheater
    cyberheater
    Apr 3, 2003
    3,190
    Scotland
    +175
    Screens don't have side to side keystone correction.
    Your Z3 should have vertical and horizontal lens shift for that purpose.
    Have a look in your manual.
  4. seka1980
    seka1980
    Mar 15, 2005
    125
    +12
    the reason i ask is that they have a panny ae500 where i work and its placed at the side of the room and on it oyu get 2 different keystone setting
    horisontal and vertical
  5. jriihi
    jriihi
    Mar 6, 2005
    196
    16
    There is horizontal and vertical lens shift. Not in menu since its not powefed one in this price range. Its near front of lens those 2 sliders. Keystone correction should be avoided since it affects picture quality.
  6. PJTX100
    PJTX100
    Dec 21, 2004
    8,132
    +563
    Virtually every PJ has vertical keystone correction but not many have horizontal correction too. Perhaps the ae500 is one of them?
    The lens shift function on the Z3 will allow you some small scope for positioning but you won't be able to get too far away from the fundamental requirement of positioning the PJ central to the screen (in the horizontal plane) - and the further you try the more it will reduce (slightly) the picture quality.
    PJ's are fantastic machines but they may require a few compromises for setup, and a few awkward conversations with the other half!...PJ :)
  7. Mark_a
    Mark_a
    May 27, 2005
    2,890
    +495
    Having said that, the Z3's screen adjust is quite impressive. It will shift the entire screen half a screen's width left or right, and a whole screen's height up or down, all without the need for any keystone correction. Though, if you have it at an extreme, either way, then that will slightly limit movement in the perpendicular, if that makes any sense? It's done using the thumbwheels either side of the lens and is entirely manual.
    Regards
    Mark
  8. PJTX100
    PJTX100
    Dec 21, 2004
    8,132
    +563
    Yep, but that's still not a license to place it in the corner of a room. And even optical lens shift can introduce some anomilies if used to the extremes eg uneven focus across the pic.
    Optical lens shift is great but it should be viewed as a fine tuning aid which facilitates things like being able to sit the PJ snug to the ceiling...PJ :)
