Need Some Help with my I.C.E
Discussion in 'Video Streaming Boxes & Services' started by 50/50, Jan 17, 2003.
  1. 50/50
    50/50
    Jan 5, 2003
    249
    16
    Nottingham
    Im going to replace my old (about 7 years old) Sony cassette player in my car. And I dont have them extractor keys. Are they any "universal" extractor keys that I can buy?
    What shall I do ?
    (b.t.w I have bought all my equiptment over the net saving me about £80, but I need to install it myself)
  2. Zone
    Zone
    Jun 24, 2001
    6,747
    Barnsley
    +2,441
    Leave the stearing wheel lock and car alarm off you'll be suprise how quickly some friendly soul will extract it for you :p
    Problem solved ;)
  3. 50/50
    50/50
    Jan 5, 2003
    249
    16
    Nottingham
    That would accually be a good idea... if my car wasnt a Mk3 Golf GTi :D
    any constructive comments ?
  4. Shoka
    Shoka
    Jan 10, 2002
    4,330
    Surrey
    +238
    There is an ICE forum now, try asking n there.
  5. Bone Daddy
    Bone Daddy
    May 1, 2001
    502
    west midlands
    +3
    Either pop along to your nearest Ice instaler - most are pretty friendly and will give you a set to either borrow or keep to extract said head unit out - they always have loads lying around or failing that off to Halfords to the ice dept` they do all sorts of extractor keys - a couple of quid should see you right ;)
  6. Miniholic
    Miniholic
    Apr 26, 2001
    3,054
    The Shire
    +398
    I went to halfords and asked one of the guys in the workshop if i could borrow a set of keys, he wasn't sure if her could lend them out, so brought them out and did the job for me instead:D
    Bare faced cheek often works.
    Ian
  7. dUnKle
    dUnKle
    Jan 1, 2001
    15,222
    +2,238
    Most can either be extracted by "making" the keys, coat hangers ( the metal ones ) or simple things such as alan kings do the job on most systems
  8. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    There is an I.C.E. forum now... here
  9. minimad
    minimad
    Where did you have it mounted to need keys???
    You got a posh dash or something?
    :D
  10. Miniholic
    Miniholic
    Apr 26, 2001
    3,054
    The Shire
    +398
    It was the one in my rover, it came with a sony head unit & changer, but it died a week after buying the car. The mini one comes out quite easily, all you need is a bit of gas, and a speedbump:D
    Ian
  11. micb3rd
    micb3rd
    Dec 8, 2001
    1,047
    48
    Bedfordshire
    +67
    If it is a old head unit then a good thing to use is long thin kebab sticks, any thing thin enough will work.
    Newer units oftern use the flat tools.
    Once the head unit is partialy out then you disconnect the arial and the standard ISO block.
  12. Darren Rhymer
    Darren Rhymer
    I used paper clips to extract mine.
    Just bought an Alpine head unit and was told that they dont use any kind of security. You can get the unit out with a ball point pen. Nice and secure!!!
    D
  13. Dave20
    Dave20
    all stereos are easily removed :D.. apart from the standard punto ones which are a nightmare to the untrained eye. oh and all the jap car that insist on have 20million bolts holding them in :D
  14. minimad
    minimad
    Dave, I sincerely hope you aren't condoning anything illegal?
  15. Dave20
    Dave20
    lol.. i used to work in a car audio shop mate :)
  16. minimad
    minimad
    I'll forgive you then :D :blush:
