Need Some Help (Sorry if its the wrong section)
Discussion in 'Projectors, Screens & Video Processors' started by Nightstalker501, Sep 6, 2005.
  1. Nightstalker501
    Nightstalker501
    Hi im looking at getting a projector and was wondering what you guys could recommend as i see there are many different types!
    im looking at spending maybe up to 800 pounds. maybe more if i find a good enough model. i am running a xbox,gamecube,ps2,dvd recorder, and vhs through my amp at the moment. can i plug my amp into the projector? is it that simple?
    sorry if there simple questions! i new to the projector thing!
    Thanks for any help.
    NS. :lease:
  2. Nightstalker501
    Nightstalker501
    anyone? :confused: :rolleyes:
    also is a 12 foot room enough space?
  3. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    If you just want a decent and big picture on the wall with the minimum amount of hassle then a secondhand LCD projector would be my first recommendation. For less than half your £800 budget you could get a widescreen LCD such as the Sanyo PLV-Z1. The rest of the money could go on a screen and ceiling bracket or you could save it towards a new lamp.
    Many of us feel that CRT will give you a better image in the long run, but it's a bigger commitment and it's worth throwing a little more money at it to get something that'll really knock your socks off :D
  4. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    yep :)
