Need some help please..
Discussion in 'Plasma TVs Forum' started by Bigmonty69, Jan 17, 2004.
  1. Bigmonty69
    Bigmonty69
    Jan 7, 2004
    826
    +73
    Posted this in the cables forum but got no response.
    I'm told you can connect a DVD player (component output) to the VGA input on a Panny 6.
    I have scoured these forums and various online retailers of cables and cannot find the prooper cable. I think it is a 3 RCA(or BNC) to 15 pin D-sub (VGA) cable. Which will enable me to connect a Jamo DVR50 to a PW6 Panasonic via component input.
    I seem only to be able to find a 5RCA/BNC to VGA cable from AV Sales which I presume will not work.
    Can anyone plz tell me if this is the proper cable for a start and if so where to buy it?
    Many thanks.
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
  3. bobbypunk
    bobbypunk
    you'd be better to buy the component input board for the plasma and a component to component cable.
  4. Bigmonty69
    Bigmonty69
    Jan 7, 2004
    826
    +73
    I was told it actually doesn't make a difference????
    It works out cheaper to get just the cable rather than the input board and the cable.
    Can someone please confirm this before I go ahead and purchase just the cable?
    Many thanks.
  5. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
  6. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
  7. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    and in answer to bobbypunk, no it makes no difference which input you use, you only need worry about a YUV card if you want to connect a PC at the same time. Even then you can buy another vga card.
  8. Bigmonty69
    Bigmonty69
    Jan 7, 2004
    826
    +73
    Thanks for the repsonses, they, along with Joe@TMF have been very helpful.
    Incidently, if I wanted to buy another terminal board, say either VGA or Component, at some point, where is the best/cheapest place to buy them?
    Cheers.
