S
Sander
Hi you all!!!
First let me introduce myself,
I'm Sander from the netherlands and i'm a newbie on the field of home cinema.
In the end of 2002 we (my girlfriend and I) started building our own home cinema
(7 X 3.20 mtrs) .From this forum i got a lot of info on screen, projector etc. (foto's will follow soon)
Now the end of the rebuilding is near i had to start looking for a good amp/receiver. On the forum i found out i minimally wanted to have a receiver with DD DTS & PL2.
Going to have a look at te other spects of receivers ...I LOST TRACK.....!!!!!!
So here is the question(s):
- Should i have EX & ES even if i dont have a 6th speaker?
- Does 96kHZ Vs. 192kHZ make much of a difference?
- When i have 8 Ohm speakers does the amp has to be 8 as well?
- Is it correct that THX isn't an option if the room is to small?
- The speakers i use are from sony (SA-VE525) and are 120 W/ch maximumpower input. Can i use a contineous120 W/ch amp, or should i go for 80W/ch?
- The last question i have is to give your opineon for the machines i have in mind at the moment
Denon AVR-2802
Onkyo TX-SR600
TX-SR700
Yamaha RX-V630
RX-V730
Sony STR-DB1080QS
STR-DB870QS
All tips on a good amp (upto 800 euro/dollar) are welcome too!!!!
Hope to get some help from you all!!!!!!!
SETUP:
epson emp7350 xga projector
Sony SA-VE525 pascal speakers 120W/Ch
Aiwa dv370 DVD
Aiwa HV-FX8700EH NI-CAM stereo videoplayer
DIY screen 2.90 x 1.80 mtrs
Denon AVR-2802
Onkyo TX-SR600
TX-SR700
Yamaha RX-V630
RX-V730
Sony STR-DB1080QS
STR-DB870QS
SETUP:
Aiwa dv370 DVD
