Need some help from a Samsung 32` LCD TV OWNER
Discussion in 'Samsung TVs Forum' started by ziggary, Jan 30, 2009.
Tags:
  1. ziggary
    ziggary
    Jan 29, 2009
    3
    LCD: Samsung LA32R81BDX
    Hello guys i need some serious help here... :(
    When settings the TV from showroom to home use i changed some settings as i didnt relise that i could change them buy going right and left....:/
    As a result even after i restarted the LCD i can no longer hear sound on the tv at all.
    I have restarted hoping it will restart the setting by going into info + menu + mute + power ---. restart but i hasnt.....(may be only restarts generic settings)
    After fiddling with master sound settings i was able to hear AV1 sound in AV2 mode...
    meaning AV! foxtel/paytv sound can be heard on AV2 (dvd).
    Can some one go in info + menu + mute + power and report the settings for me on the last line in the left bottom corner ( in main menu).. or any settings relating to the sound ...
    So i can fix this sound plz folks :)
    Update
    Going in the service menu i can see the following problem
    AV Calibration ..... Failure
    and i need settings for SGTV5810/NTP300 ( audio settings ) from main menu
    Thanks alot in advance
  2. ziggary
    ziggary
    Jan 29, 2009
    3
    common guys please this is very easy to do ?
