Need Some Help Chaps
Discussion in 'AV Receivers & Amplifiers' started by ISHANTY, Apr 8, 2003.
  1. ISHANTY
    ISHANTY
    Sep 13, 2002
    531
    3
    28
    UK
    +58
    i want to improve my music so i need to buy a stero amp but with so much chioce i dont no which one to go for have narrowed it down to three
    1. nad 320BEE
    2. arcam 65+
    rotel a-01/02
    can i have some advice
    mysetup
    yammy 630se
    b&w 602 s3f/r lcr60c asw300 sub
    jvc dvd player
    philips 775 cd player
  2. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    Own a Rotel, tried the Arcam (but bought the Rotel so that tells you my opinion) Can't stand the look of the NAD.
    I'd go for the RA-01, since it's the same under the bonnet as the 02 & £100 is a lot to pay for a remote.
    I can also tell you that the Rotel works well with a 630 for movies but you'll get itchy palms soon and want to upgrade your cd player. :D
  3. gilmore
    gilmore
    have got the NAD 320BEE and very happy with it
    Heard very good things about the RA-01/02 though... why don't you set up a demo of all three head to head - they will all have different tonal qualities so pick your personal favourite
    the RA-01 may be the one to go for (if you can do without a remote) as essentially it's a £350 amp (knocked down to £250 by exclusion of remote)
  4. ISHANTY
    ISHANTY
    Sep 13, 2002
    531
    3
    28
    UK
    +58
    thanks i made my mind up and ordered th rotel o1
  5. Jonathan West
    Jonathan West
    Was that after auditioning or just on advice from the forum? If just on advice ... brave man!!!!
  6. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    Yeah, I'd take a NAD c350 for £219 (based on demos, lol). Anyway... enjoy. :cool:
    MuFu.
  7. ISHANTY
    ISHANTY
    Sep 13, 2002
    531
    3
    28
    UK
    +58
    i heard the rotel a while ago and like it more than the nad
  8. ISHANTY
    ISHANTY
    Sep 13, 2002
    531
    3
    28
    UK
    +58
    bought the rotel RA-01 and its just what i needed for my B&W 602 s3 the sound is so much better thanks alot for this all
