First of all thanks for looking in.
Well after about 12 months of dithering whether to get a plasma or not i decided to buy one. I have been looking for around 2 month now at diffrent models etc. After deciding to go for the Panasonic VIERA TH-42PE30 i started to change my mind as with a Stand ( i cant wall mount it ) it is knocking on over my budget. So i started to look again and came across this setup
http://www.av-sales.co.uk/plasma/html/panasonic_th-42pw7b_plasma.html
Ive also see the same plasma here http://www.empire-direct.co.uk/Content/Products/Details/index.asp?modelcode=PAN-TH42PW7B but this comes with a terminal board.
http://www.empire-direct.co.uk/content/products/details/html/ALP-AG94-2-S.htm
which i thought looked a good buy, as a first time buyer of a plasma im not sure what is what and i am abit confused on what to get especialy as the 42pw7 from AV Sales seems to have the media box (i take this is instead of the terminal board ??? , aslo which is better to have termianl board or the media box ?? ). Basically i just wont to get a plasma and set it up and running wihout to much hastle any advice would be gratefully received.
Or any other setups in the region of £1.5k - 2k.
Thanks alot Crossy
Thanks alot Crossy
