Need some good rear speakers !
Discussion in 'Home Cinema Speakers' started by -=Maxed=-, Jan 2, 2004.
  1. -=Maxed=-
    -=Maxed=-
    I have some good little rear speakers and the mo but i want to upgrade... My current ones are nice and loud but they need to have a bit more mid range !
    Dont realy want to spend much but all depends on whats out there ! :smoke:
    Any good ones to look at ?
  2. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,089
    notts.
    +64
    Hi Maxed
    I swapped my mission m7ds for the small but powerful mK-k4s and they sound great only prob is they cost around 500 quid but you do get speaker brackets with them.
    Cheers Gonzo.
