Need some advices. Thanks
Discussion in 'Projectors, Screens & Video Processors' started by alex_30252, Sep 26, 2004.
  1. alex_30252
    alex_30252
    Hi, I don't know much about scaler yet.
    I like to group all my video signals (1x Composite scart, 1x RGB scart, 1x composite RCA, 1x s-video) to an optimised DVI signal (one single connection in my plasma screen). Anyone knows about any scaler or converter that can do the job? I was told about cinemateq.......
    Thank you very much for your help.
    Alex
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,400
    Rainham Essex
    +2,452
    I think most if not all of the latest scalers can do what you need. I know my Lumagen VisionHDP can as can all 3 of the Vision range. Have a look at them at www.lumagen.com
    Mark.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    have a look at DVDO range Iscan HD is what you need (wont do scart but that is overcome easily)
    What sort of budget are you looking at? Also which plasma as you need an exact pixel and sync freq match to bypass the internal scaler
    If it is an Alis panel then the Crystalio is the only option i know of that does 1024x1024
