Need some advice
BandofBrothers
Hi guys, I have got the following:
Samsung SP50L6HX (50" HDTV) (arriving in 2 weeks time)
Denon 1920 DVD player
XBOX 360 (when its out)
I would like some advice about which speakers to get for it all... and I dunno wether to get 2.1\5.1 etc etc, please help
I need speakers and an AMP
Also. do I need some high quality\expensive cables? If so...which ones are the best?
How will I be able to hook up the xbox360 AND my dvd player at once? (will 1 be optical and 1 another way?)
I'm not sure how much I am willing to spend, but can you please recommend me some good equipment (do richer sounds have anything worth buying?)
Thx for any help you can offer :thumbsup:
(treat me as a complete audio noob because I have never really had any "amazing" audio equipment of any kind...and I am in the process of pimping out my room :smashin:
Holowlegs
Hi there
I have a 1920 and paired it up with a Denon AVR 1906 amp which cost me about £269. Other may recommend others but I have been happy with this set up so far which I have had for a month. As for speakers, have heard this set up with a 5.1 Monitor Audio bronze set up, which sounded very good.
http://www.monitoraudio.com/index.htm
Cheers Holo
Trending threads
